A complete rear from most builders wont be cheap anywhere. You may be better off to find a 9" ford rear with Posi or Spool, have it shortened & spring/shock mounts moved then just buy the correct length axles.
These guys have good prices. > http://www.quickperformance.com/ads.htm |
I thought Ramblers used a torque tube drive line in a stock application?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
My Rambler wagon came stock with a 6 cylinder and 3 speed auto w/a normal driveline and rear. When I had the driveline made I just took them the original driveline and the front yoke for the 350 turbo and I had a driveline made. Took 2 days and cost around 150 dollars, including new u-joints and tube.
Okay, now remember, RAMBLER is the manufacturer's (AMC) car line name, not a model! There were different model Ramblers. Sounds like you have an American, but they changed over the years. So what year and model? That helps! A Ford Ranger or GM S-10 pickup rear axle fits the American real good. Tread was 55" for 58-69 models. Rather than a narrower axle, try deeper offset wheels. Sounds like you want wide ones on the back, narrower on the front.
All the salvage yards list the parts separately because they can sell them that way. Call and ask for the price of a complete rear end, brakes and all. They will usually give you a break on that because they don't have to handle the individual pieces. If you don't mind pulling parts yourself see if there is a Pull-A-Part or something similar near you (www.pullapart.com -- southeast and some midwest). They list prices on-line. Last time I got a rear axle (a while back!) they charged the listed price for an axle assembly (around $75 -- everything but the springs and shocks!). |
I was hoping to find something narrower without having to shorten the rear. I have custom wheels that are a Summit brand and it doesn't show what I need for backspacing. I think I will call and see if it's possible to get custom offset. I am retired on disability with a bad back among other things so I am at the mercy of my friends for the heavy work, and Uncle Sam for my money. I'll let you know what happens Thanks for your help.
Stan, what model Rambler do you have? Pre 93 Ford Ranger axles fit the American, Explorer axles fit the big cars through 1966. 90-92 Rangers with the 4.0L have the 8.8" axle, others have 7.5". Sounds like you need an 8.8" since you have over 400 hp and wider wheels and tires. The original axle for the 196 six cylinder is an AMC 15 7-9/16" ring gear, slightly larger than the Ford 7.5", but roughly the same strength. 1964+ big Ramblers (Classic, Rebel, Matador and Ambassador) used the larger AMC 20 8-7/8" ring gear axle with the six, which is strong enough. All others (Javelin, American, Hornet, Gremlin, etc.) used the AMC 15 with all six cylinders and the AMC 20 only with V-8s.
There was a 1966 only economy fleet Classic that used a 199 with AMC 15, but I've never seen or heard of one existing. Probably did, but fleet use generally meant taxis or some big company's "run-around" car -- stripper that was run into the ground then ditched. |
My car is a 1965 Rambler American model 220. When I was trying to figure out the gear ratio, I jacked the rear up and turned one wheel; the other wheel turned in the same direction, so I guess it has a posi in it. I lowered one side and got the ratio. Ratio appears to be around 4:10. It must not be working great because when I floor it , only the driver side wheel spins. What's weird is the fact that when I take off at full throttle, the car likes to get sideways thru 1st and half of 2nd.
If it's getting sideways the posi is working. It might slip until it reaches a certain speed or warms up -- might have a good bit of wear in it.
90-92 Ranger 8.8 seems to be what you need, or at least the only thing I know of that's strong and will fit without narrowing. Unless you find an early Mustang 9" -- those fit too, but are pricey! |
| Swapping '73-'77 A-body rear end into a '71, & related questions? | BinderDriver | Transmission - Rearend | 3 | 12-14-2008 01:40 PM |
| questions about rear end mounting purch modification | Riley | Transmission - Rearend | 7 | 08-09-2008 08:04 PM |
| Narrowing a 9" ford rear end | powerrodsmike | Suspension - Brakes - Steering | 6 | 05-05-2007 12:53 PM |
| 1975 8.5 rear end | camino_man | Transmission - Rearend | 6 | 09-18-2004 05:32 AM |
| Important rear end mounting question | 71gtx | Transmission - Rearend | 2 | 01-04-2004 06:05 PM |
