Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear end ratio
Thread: rear end ratio
Old 02-02-2003, 03:44 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
Post
Hey dmorris- they make wheel that you put on your axle flange that determines the gear ratio with one turn of the drive shaft (looks like a cam degree wheel). If you see one of these, notice that the open diff scale is exactly twice the degrees on the scale to get the same reading as a posi diff.
