rear end ratio (85 or newer chevy van) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2003, 09:41 AM
New Member
Post rear end ratio (85 or newer chevy van)
What kind of gear ratio would an 85 (or slightly newer) chevy van probably have? does anyone know where i can look up rear end gear ratios for chevy vehicles
Old 02-27-2003, 01:32 PM
Post
I have seen quite a few with 3.42 ratios. You can also look under the drivers side of the hood, theres a sticker that sometimes gives ratio.
There is no substitute for removing the cover and checking, you never know if it had been changed.
Old 02-27-2003, 03:14 PM
xtreme off-road's Avatar
Post
You can get your rear ratio without popping-off the cover. just jack-up the rear tires of the ground and count how many drive shaft rotations it takes to do 1 tire rotations. Make sure both tires turn at the same time. If you have 3.08s you will do just over three drive shaft rotations, and 3.73 will get 3 3/4 rotations. It's that easy.
[ February 27, 2003: Message edited by: xtreme off-road ]</p>
