Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear End Ratio - measured and number looks way too low - what am I doing wrong?
Old 07-24-2011, 07:08 PM
ggevaert's Avatar
ggevaert ggevaert is offline
Excellent
Thanks, that makes sense then and matches what the spec sheet says. I did not know that about the doubling but makes perfect sense.
I wanted to double check as the person I got the truck off of did not indicate whether it was changed and if it was already between a 3.40 and 3.80 then I wasn't going to bother as that matches the engine/tranny setup. However, I forgot about the posi part so even if the gears were correct I would have needed to change it anyway.
Cheers
