rear end rotation - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 10:15 AM
nettio's Avatar
rear end rotation
When power is applied through a pinion gear to a ring gear the rear end assembly wants to rotate opposite the direction of tire rotation. In other words the leading end of the pinion shaft wants to rotate up toward the floorboard of the vehicle. (assuming that the car is moving forward)
My question is: How much torque is being transfered attemping to rotate (or twist) the rear end assy.
Is there any way to calculate this, or any rule of thumb?
Thanks
Al
Old 07-04-2007, 01:15 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
There are mathematical models we can use for that but there are also so many variables that usually it is not done,,
This involves knowing the amount of torque being applied..the lever arms involved. and it depends on the amount of energy being applied at launch..
Sam
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 01:53 PM
Need help with my rear end chevy3600 Transmission - Rearend 3 05-04-2007 07:40 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 07:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 07:05 PM
