rear end for s10 V8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 08:02 AM
rear end for s10 V8
I've just installed a 350 cid engine and a 700r4 in my 1985 s10 4x2 blazer. Does anyone have any suggestions on good posi rear end for this combo. Posi rears for 2 wheel drive s10's are rare and 4x4 ones are 4" wider and most 4x2's are 7.5' ring gear.I would like something with the 8.5' ring gear. Anyone done this and found something that doesn't cost a small fortune. Open to any suggestions Thanks
Old 11-19-2010, 09:48 AM
big gear head's Avatar
High Performance Rear Ends
The later 2 wheel drive 4.3 5 speed S trucks and Blazers had the 8.5 rear end. This would be the easiest swap for you. The "posi" that comes in these rear ends is the Governor Lock. You will probably want to change that pretty soon after you install it. I recommend that you get a good rear end with the gear ratio that you want with a standard differential and put in an Eaton Posi or a Duragrip. You will like it much better.
You will find more information and parts for sale here. http://www.s10forum.com/forum/transmission-and-rearend/
Old 11-20-2010, 12:01 AM
Wiki Edits: 31
that 2wd 8.5" is rare and expensive when you find 1... I'v been told Ford Explorer 8.8" rear ends bolt in with a little finesse.. there commonly found with 3.73's and Traction lock limited slip/ can be found for a couple hundred at many junk yards. also '95+ have disc brakes
Old 11-20-2010, 06:00 AM
rear end for s10 v8
Thanks a lot guys I now have two more options than before. It's great to have somewhere to go for information where there are so many people willing to share info and ideas. Thanks again!
Old 11-22-2010, 03:13 PM
fast68's Avatar
likes chevy trucks & boobies
ford explorer rears bolt under these trucks so do toyota pickup rears, same pack spacing distance as the s10 trucks
shock mount mods is all needed
many toys and explorers are LSD or posi
i have some toy axles out back '84-88 style and i drive a 91 s-10 2wd pickup so ive been here measured done my research
gonna use toy 4.10 axle under mine and ditch the 7.625 3.08 open junk(4.3L Z 700r4 combo) and combine the toy leaves with the s10 leaves so i can haul more than 1800lbs on it steadily
the 4x4 toy axles are 8" theres a page online i use to decode the axle code on the tag on the firewall, it tells you ratio and ring gear diameter without even having to look at the axle at all, for example body tag axle code G292 is 4x4 8" 4.10 non LSD
around here the explorer axles are only 75 bucks complete with sway bar and all
dirt common
Old 07-22-2012, 02:09 PM
Last journal entry: after much anticipation
I believe the drivers side axle shaft and housing on the 8.8 is 3" longer and in total a few inches wider axle flange to axle flange but alot of guys buy a short side shaft and cut the axle tube this centers the diff and gets the width closer to the 7.5
Old 07-22-2012, 03:36 PM
327NUT's Avatar
Thread is 1 1/2 yrs old Superdime.....FYI
Old 07-23-2012, 11:00 AM
yes had the oops moment right after i hit send, apparently i was looking at something else and got dates confused
questions about rear end mounting purch modification Riley Transmission - Rearend 7 08-09-2008 08:04 PM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
rear end ID horses1965 Transmission - Rearend 0 06-25-2008 09:24 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
