rear end set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2005, 09:37 PM
New Member
rear end set up
hello using a model a frame and a speedway 4 link kit, ford 8" with coil overs im wondering what angle i should put the drive yoke, pinion at?
Old 03-28-2005, 10:07 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
pinion angle
4 degrees down angle is stock. High HP 5 or 6 degrees.
Old 03-29-2005, 10:12 AM
New Member
thanks im going to weld it up then today..sam
Old 03-29-2005, 10:47 AM
poncho62's Avatar
Wiki Edits: 5
Make sure the weight of the car is on it when you are measuring that angle.
Old 03-29-2005, 11:03 AM
aka Duke of URL
Doesn't the angle need to be set within a few degress of the CL of the trans output shaft?
The above sounds like a competition setting.
Old 03-29-2005, 06:27 PM
Last journal entry: Robs34 - Done my dash
Shaft angle
A lot of guys get confused when it comes to this . Remember you are building a new car here not just altering one. You need to ensure that both the trans output shaft and the tailshaft are as close as you can get to being on the same angle, for the street 3 to 5 degrees is enough. Try this; take out your springs and support your chassis with a jack at your desired ride height then try the tailshaft through your expected range of travel. this will make sure that you dont have a bind situation as U joints only have a narrrow working plane. Also remember that the diff pinion will move up and down considerably more as the rear axle has more bias due to being a higher ratio unsprung weight compared to its original location. If you are running an E brake and I hope you do, it also will influence diff pinion angle movement. When I was a registration inspector with the ASRF' I inspected a real nice 41 Willys coupe and as part of the inspection a brake test was required all was fine on the service brakes but when the E brake was applied as it would in an emergency, the pinion nosed down and the tailshaft connected with the tailshaft safety loop and if it was kept on would have caused seriour damage, just something else to consider.
Good luck with your project
Cheers from Aus: Rob
Rear End. Skunk Engine 1 11-05-2004 04:47 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
rear end traction Junior's67 Suspension - Brakes - Steering 3 11-25-2003 09:23 PM
