rear end set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2005, 07:44 AM
stickshift's Avatar
Last journal entry: selling the 60 chevy
rear end set up
hey does anyone know how many degrees a rear end should be set at? i was told about 5 degrees.
Old 04-09-2005, 08:54 AM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
__Got this from Chevy Hi pro. mag. awhile back__ For normal driveability reasons and parts wear when dirving the over all angle should be at 0. But since the rear end rotates upward. (brings up pinion angle) when you step on the gas. You have to set it down a few degrees. The angle should never go positive. For cars making good power anywheres from 2-7 degrees negative angle. The more power the more negative angle you need. 5 might be a little much unless your running a pretty hot engine or sticky tires.
Chris
Old 04-09-2005, 11:26 AM
stickshift's Avatar
thanks for the info.
Old 04-09-2005, 01:13 PM
no Problem hope that helped. The whole idea is to get things in a straight line. It allows power to be transfered easily and helps prevent wear in the uni. joints. If it is angled to much you can have things bind up. Doing read end work myself right now so i've been searching around for this kinda stuff. Good luck.
Chris
Old 04-09-2005, 06:18 PM
stickshift's Avatar
thanks chris, im putting a 58corvette rear in a 1934 chevy pickup, im using radius rods and coilovers for suspension, so i got my hands full setting up brackets and all that stuff...thanks again stick....
Old 04-09-2005, 06:26 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
The rear pinion angle subtracted from the front u-joint angle should be zero degrees. If the rear pinion angle is one degree the front propshaft should also be one degree. This greatly reduces propshaft induced vibration.
Old 04-09-2005, 06:37 PM
stickshift's Avatar
thanks for the info it helps allot...stick
Rear End. Skunk Engine 1 11-05-2004 04:47 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
rear end traction Junior's67 Suspension - Brakes - Steering 3 11-25-2003 09:23 PM
