Rear End swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 03:36 PM
Post Rear End swap
I have a 50 ford tudor and i want to know does anyone know what rearend will go in my car?
I want to put something other than the weak stock 4.10 !!
[ February 04, 2003: Message edited by: Kustom shoebox ]
[ February 04, 2003: Message edited by: Kustom shoebox ]</p>
Old 02-04-2003, 06:23 PM
Nailheadforty's Avatar
Nailheadforty
Talking
Not sure what engine you have, but regardless. Your spring center on the 50 should be 42inches.
You could use a rearend out of a 68:71 Torino as it also has a 42" spring center with a Flange to Flange measurment of 57:58" which should be close to what the 50 has under it now. May have to change the rear u-joint also.
Good Luck, and keep the rubber side down.....
Old 02-05-2003, 05:25 AM
Post
You could use any rearend from 63-65 Falcon w/V8, 65-68 Mustang w/V8, the Mavericks up to 74 w/V8, and of course the Merc equivalents (Cougar and Comet).
These are the 8inch Ford which are quite adequate for anything except the wooliest small block! Lots of different ratios around too.
The spring pads can be removed from your original junk rear and welded to the new rearend without too much hassle.
