Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear end swap
Thread: Rear end swap
Old 03-17-2013, 11:41 AM
joe_padavano joe_padavano is offline
In addition to all the problems posted above with mounting point geometry and wheel bolt pattern, the 8.5 in the B-body wagons is several inches wider than the ones in the sedans, which are still wider than the 67 A-body axles, so unless you plan to have the tires sticking WAAAAY out of the wheel wells, this is a bad idea.
The Following User Says Thank You to joe_padavano For This Useful Post:
Crosley (03-17-2013)
