rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2010, 07:52 AM
stoney 81ta's Avatar
rear end swap
Hi All,Whats involved in a rear end swap for a 81 trans am,currently have 2.56 gearing want to upgrade to either 3.08 or 3.42 gearing,have found complete rear end from a 77 camaro with rear drums as mine also,stil have to check gear ratio on it.Thanks all
Old 08-07-2010, 08:32 AM
Wiki Edits: 49
Why not just change the gear set in your current rear end? Its easier and in the end probably cheaper.
Old 08-07-2010, 08:45 AM
big gear head's Avatar
High Performance Rear Ends
The rear end from any '71 to '81 Camaro or Firebird will fit, but the u joint might be different. The early rear ends used the 1310 u joint and the later ones used the 3R, which is what you have. The location of the rubber brake hose also changed somewhere in the mid '70s. Changing the complete rear end is easier for most people who have no experience with setting the pinion depth, bearing preload and backlash.
Old 08-07-2010, 02:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 2.56 is a 2-series carrier, to put in 2.73-up gears, a 3-series carrier (2.73-up ratio) is needed, unless a spacer is used.
Rear End vibration driving me insane 973kgt Transmission - Rearend 41 11-13-2008 11:01 PM
g-body to b-body rear end swap? 95coughnut Transmission - Rearend 5 04-25-2008 01:46 AM
rear end swap john parks Transmission - Rearend 3 11-11-2003 01:47 PM
rear end swap wheeels302 Transmission - Rearend 1 11-10-2003 10:58 AM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
