-   -   Rear End Swap (http://www.hotrodders.com/forum/rear-end-swap-8965.html)
Chevydude 07-02-2002 11:41 PM
Rear End Swap
Does anyone know if there is a bolt in rear end with posi I can get from a donor that will fit into my '62 Chevy II Nova Wagon????
azmojo69 07-03-2002 10:18 PM
hello i have had luck in 68 - the early 70s model firebirds for 10 bolt posi,i have a 79 camaro z-28 that has factory posi that i just did a gear change from a 290 or so gear to a 4.10 ratio wow hole shots are great
Chevydude 07-03-2002 10:59 PM
Ahh, thank you very much. that is the info i'm lookin for!!
