Rear End Swap Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2003, 10:17 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post Rear End Swap Question
This might sound like a dumb question...BUT...I am building an S10 with a SBC(i know, i know)the truck was originally a 4cyl/5spd truck, 1989...What I am asking is this, how soon will I grenade the factory rear end with a mild built SBC? And is there anything that I should look for at the wrecking yard/swap meets for a good bolt-in Posi rear end? I guess what I am asking is what cars should I look for that would have a bolt-in rear end to fit an S10.
Thanks ,
WEIMER
Old 05-20-2003, 04:35 AM
s15laynrubba's Avatar
www.s10v8.com
Post
You should be fine with the the stock unit.I have seen 400hp sbc in the s-series last along time.Stay away from slicks, they will cause the rear to grenade in short time.I also sent you a pm.
Old 05-20-2003, 08:52 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
try www.customconversion.com click on s-10 conversions talk about rearends might help
Old 05-20-2003, 09:08 AM
Stinkin_V8's Avatar
Suburbanite Member
Post
In 1989, the bigger 7.625" rear ends started to show up in some/most of the S-10 trucks. Prior to that, it was the 7.5". The housings are fairly similar, so I don't know how to tell you the difference.
BTW, all rear ends from the 1st gen. (and maybe 2nd gens) should be a bolt-in if you want to upgrade. The 4x4 used a 4" wider axle than the 2WD but spring perches should be in the same place.
I'm runnning a 7.5" in my 350/350 4x4 S-10, it's held up just fine. I'm not running gobs of power though it, though.
SLP used to sell posi units from the F-body conversions they do for $100, you could check them out. You need 3.23 or numerically higher gears to be able to use it. Or you could find a posi/disk brake F-body rear end and change the spring perches. I'm pretty sure they're wider, but you might be able to make up for this with different rims.
When life hands you lemons, ask for tequila and salt
