rear-end or transmission ????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2002, 07:34 PM
Post rear-end or transmission ?????????
I have a 1964 c-10 truck with 402 motor and a 700r4 trans. The truck originally came standard shift and has the six lug geared down rearend. Does antone know my gear ratio? But my problem started when I changed from the th350 to 700r4 to improve gas mileage and high speed crusin. But now it doesn't shift right. It shifts fine at part throttle, but when I get on it hard it hesitates when it shifts. During that hesitation my engine over revs!! <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> The trans does have a B&M SHIFT KIT, my th350 didn,t operate like this. A friend says it's my rear end it's to low. He says when my trans wants to shift the governor is turning fast enough that's why it hesitates. ANY COMMENTS PLEASE HELP. ( TV CABLE IS OK) <img src="confused.gif" border="0">
Old 12-03-2002, 07:42 PM
BOBCRMAN@aol.com's Avatar
Post
yes 700r4's are sensitive to road speed, get a governor weight kit and follow the instructions.
Old 12-03-2002, 08:19 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Your gears won't have any effect on the governor, gears only make it shift at a different speed (MPH). The driveline RPM dictates governor action for the most part. Try this, loosen your TV cable just a little and try it to see if it helps. If the shift kit instructions came with a different method of cable adjustment, follow it.
Old 12-03-2002, 08:55 PM
Post
I tried to adjust the tv cable in and out but no results same problem. When the shift kit was installed the instructions used part of the street/ strip kit and part of rv/ towing kit. but if the instruction said to do it then it should work. Others say that I should change the servo piston, but to my understanding that would affect 2nd to 3rd shift. But I'm having this problem on all shift but overdrive is working fine that's the only thing I'm satisfied with.
Old 12-03-2002, 09:40 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Did you use this tranny before the shift kit?
Old 12-04-2002, 12:25 PM
Post
NO I DID NOT IT WAS SUPPOSE TO BE REBUILT AND I HAD SOMEONE INSTALL THE SHIFT KIT AND CHANGE THE LOCK-UP SWITCH TO A MANUAL SO I CAN CONTROL IT. BUT IT STILL SHIFTS THE SAME WAY ON OR OFF!!
Old 12-04-2002, 05:17 PM
Post
Help! help! Guys has anyone ever heard of a similar problem. I would like to know of anything I can try before I changed rearends. But my replacement is a 10 bolt from a 75 camaro!
Old 12-04-2002, 06:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
you say the engine over revs on a hard throttle shift.
Does this mean the engine revs higher than you want or that the engine RPM flairs up during the tranny shift?
Does it do this flair on the 1-2 shift, 2-3 shift or both?
Sorry for my not being too clear on what you mean.
Old 12-04-2002, 06:36 PM
Post
It revs to high not to worry about it! And it does this on all shifts when I floor it. But after the shift it returns to normal rpm. But at part throttle it does ok! What does it sound like This may sound stupid but could a weak trans pump cause this? I am running a trans cooler and when ever I touch it's warm not hot. Some say that I shouldn't use the trans-cooler and the radiator to cool it, but that shouldn't cause my problem. <img src="confused.gif" border="0">
Old 12-04-2002, 08:22 PM
Post
wasnt there some thing about using B&M shift hits on 700's a really bad idea?
Old 12-04-2002, 08:23 PM
Post
wasnt there some thing about using B&M shift kits on 700's a really bad idea?
Old 12-04-2002, 08:30 PM
Post
I also seem to have this problem in my th200 on the 2-3 shift, it doesnt shift until the motor is near 5500 and the car starts to shake, then it finaly klunks into 3rd, but I've heard this problem is common in the 200 series, something about drilling holes in something and not enough pressure, but thats all I know. Sorry about the double reply, hotrodders.com seems to not be working well tonight.
