rear end vibration
You may be causing too much of a driveshaft angle with the new rear end. I have had problems as you have had and once I rule out the driveshaft, drums, and axles I also move to adjust the driveshaft angle. Of course you either need to raise/lower the transmission or most likely your rear end is either pointing to much upward or downward. I don't have the specs but there are many articles posted here with the correct specs.
Well after all this time, the problem still exists. If I put my car up on jack stands and start the engine and put it in drive to watch the wheels spin the drivers side looks good. The axle slides in and out like butter when im taking it apart and reassembling. The passenger side has a noticeable circular wobble to it and it is a little harder to slide the axle in and out of the housing when working on it. Almost like the axle is getting in a bind just before its pushed in far enough to get the c-clip out. I thought it was a bent axle even though they are brand new so i swapped it for another new one....same deal.
Could it be something in the differential? outer axle bearing? bent housing? The diff is a brand new Eaton posi...the bearings are new....everythings new expect the housing I got it at the junkyard. Car wasnt wrecked. Please someone give me some suggestions. I keep spending hundreds of dollars to get no result. |
Try swapping tires from side to side and see if the problem switches sides as well. If ity does, then you know the rims tires are the thing to look at..
If not, I'd spend 20 more dollars at a discount tool store on a dial indicator and magnetic base and start checking runout on the axle flange, axle center spud ,(the protruberance that the rim centers itself on). Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Just for info's sake , do you mind if I ask what the boneyard charged for the Squad rearend? (I have 2 Caprices, 1-86,1-89). I'm not trying to be nosey, it's just that I may need 2nd upgrade in the forseeable future. (I got the 3.08 that's in my '86 from a complete '83 donor car I got for $100, the '89 still stock/open). -Just curious what the boneyards might charge for P.I. rearend. -Jim (If not comfortable with posting that answer on the thread, then just pm me. -If you don't mind giving an answer, that is).
Loosen up the 4 mounting bolts for the rearend and ck. Than tighten bolts back up at ride height .
He'd better put a plug in the back of the trans if he wants to run the motor and trans with no driveshaft...Otherwise he'll be cleaning up a big pool of oil. Are you saying that the rear end pinion angle needs to be 2-4 degrees down in front,or down at the rear? The way to properly measure the pinion angle is to put the car up on stands with the suspension loaded, then measure the angle of the motor, then measure the pinion angle...In most cases, the pinion shaft needs to be set up so that under a load, the shafts become parralel. With the type suspension he has, that would make the pinion shaft set on an angle that is 1-2* greater than the angle of the motor. You also need to consider the operating angle of theU-joints, which could be way off if the car has been excessively lowered or lifted. Check this link out.. http://www.drivetrain.com/driveline_angle_problem.html Making sure the suspension bolts are tightened up when the car is at ride height and checking the driveshaft can slide into the trans are good ideas. Later, mikey
I dont know how to check for axle run out. Ive never used a dial indicator before. I might be able to figure it out.
I got there on a half off day and scored the complete rear minus drums for $50.00 It had 3.42 gears in it originally. It has the large drum brakes.
Its definetly something to do with the right axle or something. Even with the wheel off it looks wobbly. Its a little tight going into the splines on the differential as well. The other side is great. I know now its not the driveshaft, pinion angle or transmission. I cant run the tranny with the driveshaft out. It will make a big mess not to mention the shaft is floating without the slip yoke of the driveshaft slid in there to ride on the bearing. The output shaft would flop all around and cause damage im sure.
I think i'll shoot some video of the axle and let you all see what I mean. Keep the suggestions rolling in though maybe I can get it nailed. I appreciate all the response!
The flexible arm type base is easier to work with, but more expensive. here is the results I got.. http://images.google.com/images?hl=e...h+Images&gbv=2 Later, mikey
Normally,If it's a angle causing the shake, it will do it under acceleration or decel. Double check the u-joint at the rear,That year of car should have a joint with Spicer#5-3147X, To double check this,Your pinion yoke should have NO Tab's on the outside of the yoke to center the joint.That joint uses inside snap rings on the cap to center the joint in the pinion yoke. I've seen many instances where people forget to put the snap ring's on the cap's and it will vibrate. Just something to double check.
Cap Dia of the joint is: 1.125 Snap ring dimension "inside" : 2.562 O/A width "outside to outside cap" : 3.370 |
Thanks for answering my nosey question about the cost. I would have figured more $ than that for a factory posi unit from boneyard. I did notice a mention in your earlier portion of the post that may warrant closer attention. Specifically :The passenger side has a noticeable circular wobble to it and it is a little harder to slide the axle in and out of the housing when working on it. Almost like the axle is getting in a bind just before its pushed in far enough to get the c-clip out. I thought it was a bent axle even though they are brand new so i swapped it for another new one....same deal.
Could it be something in the differential? outer axle bearing? bent housing?. I wonder if POSSIBLY the axletube could have been tweaked or bent if the squad jumped a curb during a chase? Because the tubes are only press-fit into the centerhousing and not normally welded, (unless modified by a hotrodder) I would really be curious if this could potentially be your problem? -Hope you find the cause soon, and can return to actually enjoying your ride. -Jim |
| 4x4 12 bolt rear end same as 2wd rear end??? | Ed ke6bnl | Transmission - Rearend | 2 | 05-24-2008 02:25 PM |
| 8.8 Ford rear end in my 79 G body Malibu | 79 Malibu327 | Transmission - Rearend | 4 | 05-20-2007 02:26 PM |
| Rear End Gunk? | MrChevyDC3 | Transmission - Rearend | 2 | 02-19-2004 05:48 PM |
| Rear end identification help | 71gtx | Transmission - Rearend | 1 | 11-07-2003 07:14 PM |
| Ford Pickup Rear End | Kaylah | Transmission - Rearend | 6 | 05-09-2003 03:14 PM |
