-   -   REAR END WIDTHS (http://www.hotrodders.com/forum/rear-end-widths-10570.html)
DossWallace 04-14-2003 07:56 AM
REAR END WIDTHS
I AM TRYING TO FIND A STOCK REAR END FOR MY COUPE TO AVOID HAVING TO GET A NARROWED UNIT. THE FACE OF DRUM TO FACE OF DRUM DIMENSIONS NEEDS TO BE FROM 50-1/2" TO 53". WILL BE RUNNING SMALL BLOCK CHEVY. DOES ANYONE KNOW OF A STOCK UNIT THAT FITS THAT CATEGORY? I WAS WONDERING ABOUT MAYBE AN S10 OR SOMETHING LIKE THAT. ANY HELP WOULD BE APPRECIATED.
THANKS
pasadenahotrod 04-14-2003 08:22 AM
It would be helpful if you told us what kind of car you have....many of us might jump to the conclusion that you have a 37 Studebaker 3W Coupe or 49 Chevy Coupe! See what I mean?
stea 04-14-2003 01:34 PM
thats pretty narrow, I think even an s-10 is about 58". MAy want to look for a 9" and narrow it.
68NovaSS 04-14-2003 02:11 PM
The narrowest Ford you'll probably find is a '74 Maverick 8", it's 56.5.
The link below has some Ford links that may interest you.
<a href="http://www.kevinstang.com/Ninecase.htm" target="_blank">9" Links</a>
Larry
Jason 04-14-2003 02:33 PM
I took a 7.5 out of an '87 S-10, it was 55" from drum to drum (wheel mounting surface).
Ted's37 04-14-2003 04:15 PM
I think he is measuring flange to flange, as IU have a 37 Ford Coupe that is about the same measurement. I also am looking for a rear end to use.
Jason 04-14-2003 05:26 PM
[quote]Originally posted by tlauerjr:
<strong>I think he is measuring flange to flange, as IU have a 37 Ford Coupe that is about the same measurement. I also am looking for a rear end to use.</strong><hr></blockquote>
Flange? as in wheel mounting flange, wheel mounting surface, brake drum. OK to be more clear the S-10 rear measures 55" from where the rim touches the drum on one side to where the rim touches the drum on the other side.
