Rear-ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2005, 05:06 PM
Rear-ends
Where can I read up on rear-end rebuilding and repair? Online sources, perferrably. I am little short changed due to saving up for car parts. I'm not rebuilding mine, I am just looking to expand my wealth of knowledge. Thanks in advance.
-GIJoe
Old 06-02-2005, 06:06 PM
It would be a good idea to list what car you have and also which axle you have (if more then 1 type could be in the car or if something else is swapped in). It is hard to give specific info without that data.
That being said these are some of the GM (mostly 10-bolt) links I have:
http://www.xse.com/leres/ss/differential.html
http://www.fullsizechevy.com/fscu/axletech/
http://www.drivetrain.com/gm8.5.html
http://www.2quicknovas.com/happyrearends.html
Old 06-02-2005, 07:51 PM
I have a 1973 Pontiac Ventura. Thanks for the links.
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 10:05 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
chevy 10 bolt rear ends Adrenaline_Fiend Transmission - Rearend 5 08-04-2003 10:32 PM
Nova Rear Ends Rick Yocum Transmission - Rearend 7 11-19-2002 06:30 PM
Rear Frame Kit-JEGS beetle9 Suspension - Brakes - Steering 0 04-18-2002 05:51 AM
