Rear ends...ring gear..? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2003, 06:24 PM
New Member
Post Rear ends...ring gear..?
I have many questions about rear-ends-
Ford's 9'' is the strongest rear-end ive heard (dont know about danas) so ideally, bigger the ring gear the stronger right? so does the 9'' refer to the ring gear size? then what is 8.8 bolt? how about the GM rearend ring gear sizes?
Old 01-23-2003, 06:58 PM
Post
Yes ....the 9 inch is a reference to the ring gear. Same for the 8.8.
Danas are some what more heavy duty but
1) are way too heavy
2) hard to work on. The axle bearings are a pain in the bottom.
3) they are Spicer type...... means gear changes have to be done in the housing ( no center section swaps like the 9" Ford)
4) Narrow Danas are almost non-existant from the factory and they are hard to narrow.
