first off, be positive it`s oil and not gear oil, the smell should tell the difference, gear oil after many miles of use gets thin like motor oil does and looks almost the same. if it is gear oil then I`d say the front seal in the tranny is leaking, check the gear oil level in the trans and see if it`s low, if it is it`s a good possibility it`s the seal. if you think you should change the gear oil I`d recommend moroso`s "climbing" gear lube, this stuff climbs the gears with a sticky action that helps the shifts become real smooth and almost effortless, it also reduces trans wear. being it`s thicker it may reduce the tranny leak all the more.
Sorry I should have said that before. I did suspect the trans at first but I changed the oil in the 3 speed recently and replaced the rear seal also. The trans is tight. I checked the level and it's fine. The oil that is coming out is definatly not gear lube. I changed the pan gaskets because we had the engine out replacing the cam, intake etc etc and repainted the motor. Replaced all the gaskets. When a rear seal leaks, where will the oil end up usually?
im in the same place the rear pan seal is leaking like a sive i its ok on start up then beginns to flow/ what pattern of leakage may identify a rear oil pan seal leak
my 327 leaked all the time. we changed the seals 3 times and it wouldnt stop leaking, the oil senser was lose on top where the manifold was and the oil went all the way down to my tranny. i got that tight and good but i still had a leak. i looked at my oil filter and it had not been put on right, the seal on it bent to the side when we put it on, maybe you should take a look at thses 2 places and see if that could be it, and maybe your manifold might be leaking from the back aswell. but it dosent hurt to take a look.
Good luck |
