rear frame-pro street 35 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2002, 04:22 AM
beetle9's Avatar
Question rear frame-pro street 35 ford
I am building a 35 pro-streeter and an wondering about the rear frame section. I have a local who is offering to build a tubular rear frame who seems very knowledgeable and the price is reasonable. On the other hand, there are frame (ladderbar kits) available from several sources, Jegs, summit etc. I have seen some negative comments regarding the kits, especially the use of the coilover suspension on street rods. Therefore, I am leaning towards using leaf springs and some kind of sway bar. Would like to hear some opinions.
Old 05-09-2002, 07:03 AM
New Member
Post
The coil-overs should work just fine for street use.I would avoid a triangulated bar set-up as you can get binding on the street.Go with a panard bar and four link set-up and you should be in good shape.
