rear and front axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2007, 08:47 PM
hello well have the frame boxed and a suicides front end hung the stock axle from a bracket of the tube/ got a truck rear axle 11 " brake drum removed the brake drum out of the old spoke rims bib hole pattern my problem is the 11 ' brake drum on my axle don't fit inside the spoke rim. I need a axle with 9 ' drum my engine is a 351 Windsor . I need to know what to use . I want to use the big hole pattern old original spoke wheels. can anyone help.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
