-   -   rear gear affects on 1/4 mile (http://www.hotrodders.com/forum/rear-gear-affects-1-4-mile-135447.html)
smokin63 03-20-2008 05:10 PM
In the process of building a new motor for my 63 Nova , it currently has 3.90 gears in the rear end with a 26 inch tire . The motor is going to be super charged with close to 600 hp +/- . I already know its going to run out of gears with the 3.9s and about perfect would be 3.55s . How much affect on the 1/4 mile time would going to a little taller gear to make it a little more freeway freindly be , like going to a 3.00 ? I am estimating low 10s in the 130s mph
ernkazern 03-20-2008 05:53 PM
What do you have for a trans? An overdrive trans is a great match with a low (high numerically) gear. The 700R4's big brother, I can't think of it's number designation right now, should be able to handle 600 hp with no problem.
smokin63 03-20-2008 06:18 PM
Current trans is a th350 with a shift kit and 3000 stall convertor , I was thinking it would be alot less money for rear gears than a trans .
car is a weekender only so its not driven alot . After I get done paying for this motor I want to do a new paint job , so there goes another years worth of Fun money , I was also thinking about bolt on overdrive Like the V02 but its like $1500 , can almost do the 700r4 for that .
ernkazern 03-20-2008 06:26 PM
I thought I read somewhere that a 700R4 wasn't reliable for over 500 hp. It's bigger brother that GM puts in the pickups will take it though. You may save $500 by changing the gears instead of the trans but you'll have a lot less fun, IMHO.
elvis66chevelle 03-20-2008 06:39 PM
with a 3.90 gear it be cheaper to go with higher tires 28" high should work. or you can go to web sites that will give you rpm with these tires and gears in 1/4 mile.
ImRoyaltyInMyChevy 03-20-2008 06:46 PM
when you guys say 700r4's big brother, do you mean the 2004r ? thats the one that they put in regals and cutlasses
BMM 03-20-2008 07:01 PM
I think they mean the 4L60 and 4L80E's.
ImRoyaltyInMyChevy 03-20-2008 07:03 PM
ok yea, the truck ones, but I thought those were for the newer blocks only
tomslik 03-20-2008 07:05 PM
4l60 IS a 700R4
4l60E needs a puter to shift...
same as a 4l80E....
4l80 being a heavier duty trans..
HalfOunce 03-20-2008 07:06 PM
It sounds like they are talking about the 4l80e.
ImRoyaltyInMyChevy 03-20-2008 07:09 PM
can they run on a non computer controlled engine? meaning it doesn't need to hook up to the ecu, does it have its own ecu that you can just put in for the tranny itself
DeathRattle 03-20-2008 07:35 PM
I am pretty sure they have mods to run full manual on the 4l80e...as long as shiftin all the time doesnt bother you.
They also have controllers priced anywhere from 1000 to 1900 dollars.
Anyway you you try it the 4l80e route is a pricey one.
Either spend it on gas or spend it on an OD transmission. I cant say it will take a long time for the transmission to pay itself off in gas the way gas keeps rising.
Things to ponder for your project.
454C10 03-21-2008 08:10 AM
Depends on the engine rpms. my car trapped 135 mph with a 3.90 gear, 26 inch tall tires, around 6800 rpm at the end of the track. This is with a final trans ratio of 1:1.
First you need to figure out what will be your engine's max rpm? Then pick a gear and tire diameter so that it hits the max rpm at the target trap speed.
red65mustang 03-21-2008 11:42 AM
here's some simple gears and tires changes calculators....plug in values till you find what you want
http://www.tciauto.com/Products/Tech...alculators.asp
tomthecomic 03-24-2008 10:47 AM
355
3.55 will get you 130 in 1/4 at about 6000. Your 60 foot will suffer with the 3.00 but not much you might be looking at .2-3 more time in the 1/4 so a 10.3-10.4 not a 10.1
