Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear gear affects on 1/4 mile
Old 03-21-2008, 07:10 AM
454C10 454C10 is offline
Depends on the engine rpms. my car trapped 135 mph with a 3.90 gear, 26 inch tall tires, around 6800 rpm at the end of the track. This is with a final trans ratio of 1:1.
First you need to figure out what will be your engine's max rpm? Then pick a gear and tire diameter so that it hits the max rpm at the target trap speed.
