rear gear change
I have a 1966 Impala with a 530 HP small block. 3200 stall. I currently have 3.73 rear gears with one tire fire. Here is my situation........
I am going to switch to the 700R. But am unsure wether I should go with 4.11's or 4.56 rear gears. Either with the overdrive will be under 2600 RPMS at 65 mph which I really like. But with the lower gears in the 700R would 4.11's be the ticket? Or 4.56's? And is it true that a 700R can have a adustable stall? And how realiable are 700R when build properly....?? My turbo 350 has been bullet proof. But I want the best of both worlds..... Light to light quickness. And freeway capablitity......
And with my rear end. I have the 10 bolt setup now. When I switch gears will the ten bolt hold up? Or do I have to go with a 12 bolt?
Any help would be greatly apprecitated........
Dave
