rear gear changes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2005, 02:17 AM
black66's Avatar
www.airriderz.com
rear gear changes
I am switching to a 700R and am going to change from 3.73 rear gears to 4.56's. I have one tire fire now. What parts will I need to do this change to posi?
Thanks.....
Old 07-23-2005, 09:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
More informaion needed.. it appears you are working on a GM vehicle?
Make , model , year of the vehicle?
Thanks.....
Old 07-23-2005, 06:26 PM
71 c-10's Avatar
just a kid and his truck
well first off, your going to have to find out if your drive shaft needs to be shortened or lengthened. then you need to a 4 series posi carrier, your 456 gear set, make sure the carrier is for the right size rear, 10 12 bolt etc. then when you get the gears get an in stall kit with shims for the pinion and carrier. Your probably going to need a dial indicator to set the pre load on the gear's as well.
Rear Gear Oil Problem. help 71gtx Transmission - Rearend 4 03-03-2004 08:26 AM
rear gear ratio options. s-10 Evan Transmission - Rearend 2 08-16-2003 11:49 PM
rear gear kruzr Transmission - Rearend 2 01-19-2003 05:58 PM
Rear Gear Oil dollybud Transmission - Rearend 4 07-04-2002 11:23 AM
