Rear gear choice, Gear to Tow - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2002, 08:10 PM
New Member
Post Rear gear choice, Gear to Tow
72 C10 Pickup
283ci engine
700 R4 Tranny (3.06, 1.63, 1, 0.7)
This will have 31" tires and the current rear is a 3.07.
I don't know if that setup will lend itself to hauling well enough. Truck needs to be able to tow 5000 lbs at highway speeds. And yes I know the 283 isn't all that large. But I believe in it!
So taking whereever the power band is in the engine into account, somehow i need to determine the optimal rear gears. Would a 4.10 be streetable?
Help!
Old 12-02-2002, 08:42 PM
DoubleVision's Avatar
Post
with that tall a tire and 700R4, the 4.10`s would work, but I believe 3.73`s would also, i posted on your post for running the 307. I`d run it because it has a longer stroke and makes more torque, with the 307 engine, 3.73`s would be okay, but the 283, i`d run the 4.10`s.
Old 12-03-2002, 02:07 AM
Tazz
Cool
Is there a site we can go to for info on gear ratios and tire combos? I'm running 33X19.5X15 on my chevelle and rthe gears I have now are like 2.25 in a ford 9". I think the gears should be like 3.90 something for performance. 3.50 for highway. And I'm not sure what the 2.25 is good for except hold the rearend together!
Todd <img src="confused.gif" border="0">
Old 12-03-2002, 07:17 AM
New Member
Post
http://www.ring-pinion.com/calculators.shtml#
They have an RPM calculator, which you have to interpret according to your needs, but it works.
If you want to know the equations, for fun.
Tire Circumfrence (Diamiter x 3.14) divided by (MPH x 1056) times your rear gear (3.73, 4.11 etc) ratio, times your transmission gear (3.06, 2.52, 1, 0.7 etc) ratio gives you engine rpm.
Given it will be a little higher because of drag, but hey... its close enough for me.
