Rear gear ratio ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2011, 07:45 PM
newportman's Avatar
Rear gear ratio ?
What is the best way to determine ratio of rear gears ?
Old 02-14-2011, 08:33 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Pull the cover and count teeth on the ring and the pinon. Divide ring count by pinon count equals gear ratio.
Old 02-14-2011, 08:40 PM
newportman's Avatar
Thanks a lot !
Old 02-14-2011, 09:04 PM
327NUT's Avatar
Do you have a cover or is it a 9" type? Some times you can find a metal tag on the 3rd member or if you don't want to pull it count the revolutions of the driveshaft by turning the tire exactly 1 rotation. Not real precise but it will get you in the ball park.
300 z turbo rear , what gear ratio? tomcraft Transmission - Rearend 1 06-18-2009 06:24 PM
cam/rear gear ratio Highperformace Engine 8 04-12-2009 08:33 PM
rear end gear ratio mechanix54 Introduce Yourself 2 02-22-2006 12:22 AM
VIN # and rear end gear ratio olds79 Transmission - Rearend 1 11-24-2005 09:17 PM
What is the gear ratio for a GM rear end? jpd37 Transmission - Rearend 6 02-23-2004 01:52 PM
