We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-06-2003, 07:05 PM
68firechicken 68firechicken is offline
rear gear ratio with 700R4?
i plan to swap my rear end out on my 68 firebird. It's a 10 bolt open rear with what i think are 3.08 gears. I am going to eventually swap out the transmission to a 700r4 and I was wondering what rear gear ratio would best suit this swap. the overdrive on the 7004r would allow a higher ratio, but i believe the only options i have for the 8.2" 10 bolt are 3.55, 3.90, 4.11, and 4.56... which one should i use?!
(this is not a drag racer, but more of a street/strip application) thanks for the help,
Brad
Old 10-07-2003, 12:55 AM
Blown72Camaro Blown72Camaro is offline
The 700r4/4L60E has a low 3.06 first gear so I would go with 3.55 - 3.73 gears at the most.
Other wise you will be spinning more than running hahaha
Old 10-07-2003, 04:57 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The 3:55, or 3:90 is what you want. That will put your highway rpm around 2100 to 2600rpm.
Vince
Old 10-07-2003, 05:22 AM
EBlack36's Avatar
EBlack36 EBlack36 is offline
Rebuilt Excitment
I am running a 9 inch Ford rear with a 200R4, which has a little better first gear with 225/70r15 tires and I am using 3.55 gears on the hiway about 70MPH I am turning about 2400 RPM's on level ground.
Old 08-06-2006, 12:58 PM
chevmal chevmal is offline
gears
410s would really make your car jump with a 700r4. You would still have a .70 to 1 final drive for cruzing.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
