Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear gear selection
  #18 (permalink)
Old 01-20-2013, 07:09 AM
dave350v8 dave350v8 is offline
Originally Posted by F-BIRD'88 View Post
Get some tires that have traction. If a 23" is as tall as will fit, make sure its a sticky drag radial.
EG: P225-50-15 BFG drag radial. A normal street radial tire is all but useless at the track. They are made for long life not straight line traction.
A 8.5x 26x 15" M/T ET street Bias ply tire which is effective 25.5" tall will make a huge difference.
Its real hard to get a good track ET with a crap tire, reguardless of the gear ratio.
You will know you got it right when the front wheels go airborne on launch.
You got to get the weight back on the back tires to get a small tire to hook up. Weight transfer. But you do not want the rear suspension to squat on launch.
You can rev that engine a lot higher than 5500 rpm without fear of hurting it.
if thats is your self imposed rev limit port the camel backs and reinstall.
The 600VS carb is not doing it any favours. What is the exhaust system like?
Its all about total system air flow. Heads are only one component of the air flow chain.
Thanks for that, on the strip last year 1st gear would not grip, so recently
boughts some toyos r888 super softs,took it down the road broke the rear diff
(ford atlas axle out of capri 3.08 gears) just putting a explorer axle under,the axle has:
3.73 gears at moment,but have got a set of 3.31 and 3.08 gears as well.shall
I stick with 3.08 then? More cam and better headers? I have only block huggers at moment?
I thought 5500rpm would be max on standard bottom end?
Thanks for your imput!
