Rear gear selection help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 06:30 PM
karfever's Avatar
38 Chevy Coupe Ram Jet 502
I have a 32 3 window and want to change out the rear gear. It presently has a 4:11, which is far to low for me, I cant drive much over 65 without the engine reving a bit too much for extended drives. Here are my specs;
350 Chevy, 2x4s aggressive cam(Voodoo 540 lift) p1 GM angle plug head. About 370HP
Built 350 turbo, 2400 stall
Rear- Ford 9 in trac-lock 4:11 gear
I am thinking about dropping to a 3:50 ratio, but am looking for some real world advice.
Thanks all!
Old 07-28-2010, 07:22 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If you do a lot of extended driving, You might think about putting 3.25s in it.
Posi Rear end gear oil problem stinky jinx Transmission - Rearend 16 05-14-2006 02:02 PM
VIN # and rear end gear ratio olds79 Transmission - Rearend 1 11-24-2005 08:17 PM
rear gear change black66 Transmission - Rearend 3 03-17-2004 06:54 PM
3.70 rear end gear change lori-due Transmission - Rearend 3 12-28-2002 08:25 PM
