Rear Gearing Recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2013, 10:59 PM
Skips Blown 55
Guys.....
I know that you have been asked this question a thousand times, but this is 1001 !!! Best all around rear gearing...........street/highway
I have a Blown Big Block 55 Chevy with the following:
496 full roller motor
8:71 blower running heads up (1 to 1)
Dual 950 Holley carbs
Comp Cams Roller (a little better than BDS Stage 2 Race Cam)
Turbo-400 1/2 built
Full Chris Alston back half
31 X 21.50 X 15 tires
American Racing 15" DEEP rears
Alston/Ford housing (9")
35 spline axles with big bearings
Four-Link suspension
I can do the calculator formulas, but what is your personal recommendations for the final gearing for mostly street and some highway. I say that I'm not going to run it, but there are others that have said the same thing !!! This is mainly for two old people to get hamburgers in. I am looking for best all around by experience, not calculator.
Any and all recommendations are greatly appreciated.
Thanks,
Skip
Old 09-20-2013, 04:06 AM
302 Z28's Avatar
3:50 to 3:70 would be my choice.
Vince
Old 09-20-2013, 06:33 AM
Look up your camshaft information. there should be a "cruising RPM" for it. I wouldnt go any lower than that (numerically). But my guess is the same as above; 3.55 - 3.70:1. Remember, if you have a tall rear tire, it makes the rear gear ratio seem lower (numerically). Use this calculator. RPM/MPH From Gear Ratio Calculator by Wallace Racing
Input the height of your rear tire
Your trans ratio is 1.00
then choose 3 rear axle ratios; say 3.42, 3.55, 3.70
Pick the highest ratio that meets your RPM needs on the highway. But with a roots blower and not looking to run an ET; Id probably pick the 3.55:1. Its still going to be a riot to drive
Old 09-21-2013, 08:25 PM
Skips Blown 55
Final Rear Gearing
Thanks Guys..........
I was thinking in the 3;50 range also. Wanted to make sure that I wasn't going too high. Had thought about 3:70, but thought I would give up more on the freeways.
I forgot to mention the cnc'd Big Brodix heads. I don't think that I'm going to be on the EPA's "Happy Birthday List".
Thanks again,
Skip
help determining rear gearing loafing1 Transmission - Rearend 2 10-23-2010 04:31 PM
700r4, Rear gearing... DarknessSpawned Transmission - Rearend 4 03-05-2008 02:09 PM
79 trans am rear gearing Rough-Rider Transmission - Rearend 3 02-05-2007 08:12 PM
79 trans am rear gearing Rough-Rider Transmission - Rearend 4 01-23-2007 08:16 PM
Rear end gearing underdog305 Transmission - Rearend 10 02-27-2006 12:39 PM
