Rear gears to use with a 3000 stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2003, 11:08 AM
dion's Avatar
72 Chevy Cheyenne
Post Rear gears to use with a 3000 stall
I have 3.55's now, with a 31 inch tire what differences would I get performance wise with a 4.10 rear?
It's a SBC with close to 400HP
Old 06-01-2003, 09:43 PM
Post
[quote]Originally posted by dion:
<strong>I have 3.55's now, with a 31 inch tire what differences would I get performance wise with a 4.10 rear? About 18% more engine torque.
It's a SBC with close to 400HP</strong><hr></blockquote>
What TC are you using? STR Ratio with that 3000 rpm stall?
You may have some traction issues with those gears as our trucks are pretty lite in the rear....plus you may not like the higher rpms at freeway speeds...reason I'm staying with the stock 3.73 gears and going with a TC with a 2.2 STR with a 3000 rpm stall.
You can use this to figure out what mph you will be running in each comparing the two gear ratios.
<a href="http://www.smokemup.com/auto_math/mph_range2.php" target="_blank">http://www.smokemup.com/auto_math/mph_range2.php</a>
Ken
