rear ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2005, 09:56 PM
ss396si's Avatar
rear ID
hi
i have a 10 bolt rear (non-c clip) out of my 69 chevelle
the id is 1235197.
is this the 8.2 or the 8.5?
thanks
Old 06-05-2005, 12:23 AM
adventureseeker's Avatar
Monkeywrench
Not much help, but.....
http://www.chevelles.com/years/69/69rearcodes.html
I came across this site when looking for info on El Camino's since there are no web sites on GMC Caballeros. Hope this site helps.
Old 06-05-2005, 12:27 AM
circletrack62's Avatar
hey you might check a chilton's manual
Old 06-05-2005, 04:08 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
rear
Some id sites with pics
http://www.novaresource.org/axle.htm
http://www.oldsmobility.com/10bolt-tech.htm
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
