Rear leaf spring modifications! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2008, 04:08 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Is it possible to safely move the rear end backward on a leaf spring suspension? For ex. drilling new center bolts that the rear end mounts too, the bolt that holds the leaf spring together (4 leaf spring system). Or is it best to just move the mounts backward to get added wheelbase?
Old 03-24-2008, 04:21 PM
Will I ever get it done?
Last journal entry: Hood
How far? It is a common way to center the tires in the wheel opening of a 41-48 Chevy by drilling new holes about an 1-1/2" back (IIRC) in the stock springs. I don't recommend this on the 41-48 because the stock springs are designed to only hold up the car. The torque tube prevented the rear end from twisting when accelerating or braking. With an open drive shaft, the springs control the torque, and I feel you need stouter springs for that. In your case, I am assuming you have the proper springs, you just need to adjust the wheel base. You should consider the affect this will have on the springs ability to control the rear end twisting, the spring rate, and the ride quality.
Rear Leaf Spring Shacle Bolt for a 1937 Buick Special SteveHotRod Suspension - Brakes - Steering 9 11-05-2007 07:46 AM
Leaf Spring Rebound Problems fredetl Suspension - Brakes - Steering 1 03-28-2007 11:57 AM
Flipping leaf spring cboy Suspension - Brakes - Steering 16 03-05-2007 04:53 PM
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 12:04 PM
Rear Leaf spring kits greywulf Suspension - Brakes - Steering 2 03-06-2005 01:24 PM
