rear leaf springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2008, 02:04 PM
rear leaf springs
I searched the forums and could not find anything to answer my question. I had new rear springs made for my 52 chevy 2dr sedan and they are way too firm which gives me an all too high of a ride height. This is because they used flat spring stock as compared to the original tapered spring leaves of the original ones. As well the overall springs pack is about 3/8 inch thicker than original. I am thinking of taking apart my original springs and cleaning them up and using all but the main spring with the new main spring. of course the original springs have the centre hole approx 2 inches off centre. Should I install them with the longer part to he front? Would that help with potential axle hop?? Also, should I paint the springs prior to assembly or is it best to leave them bare metal. Maybe teflon tape inbetween to prevent any squeaks??
Old 02-07-2008, 02:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You could use the new springs and put lowering blocks on them...if the ride is too rough , you could take a leaf out .
Old 02-10-2008, 09:06 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
The shorter section should go in front of the axle, the more rigid this section is the less it will wheel hop. The leaves slide on each other so you can put grease between them, thats what I did. You can experiment with removing leaves, or mixing between your sets. If you want to keep a firm spring rate but lower it down some take the leafs to a local spring shop and get them to de-arch them a bit.
donor rear leaf springs for 38 ford 38harry Suspension - Brakes - Steering 1 10-31-2004 06:58 PM
Rear leaf springs, lowring blocks, and air bags? Cowtown Punk Suspension - Brakes - Steering 2 07-06-2004 05:33 PM
Rear Coil Springs bigjoedo Suspension - Brakes - Steering 3 02-23-2004 02:02 AM
Rear Leaf springs Help 39chevy Suspension - Brakes - Steering 1 09-22-2003 06:43 PM
Better leaf springs or 4 link? whytry Suspension - Brakes - Steering 25 09-02-2003 05:34 PM
