rear leaf springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 01:27 PM
rear leaf springs
Q. on parallel leaf springs,should the distance between front to front & back to back of springs be same distance.Local shop installed new leaf springs on a partner of mines 46 Chevy's pickup.The front of the springs are 3" narrower than back of the springs.
Old 11-05-2005, 02:05 PM
BOBCRMAN@aol.com's Avatar
It is common for rear leaf spring setups to be narrower in the front.
Old 11-05-2005, 02:31 PM
I guess they aren't parallel then are they
donor rear leaf springs for 38 ford 38harry Suspension - Brakes - Steering 1 10-31-2004 07:58 PM
Rear leaf springs, lowring blocks, and air bags? Cowtown Punk Suspension - Brakes - Steering 2 07-06-2004 06:33 PM
Rear Coil Springs bigjoedo Suspension - Brakes - Steering 3 02-23-2004 03:02 AM
Rear Leaf springs Help 39chevy Suspension - Brakes - Steering 1 09-22-2003 07:43 PM
Better leaf springs or 4 link? whytry Suspension - Brakes - Steering 25 09-02-2003 06:34 PM
