Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Leaf Springs ...."Clamping Them?"
Old 03-06-2006, 10:36 AM
barnym17 barnym17 is offline
a trick we use on dirt cars is to slide the second leaf forward under the spring eye, redrill the spring, reverse the third leaf so the front ends up under the spring eye, leve the bottom leaf as it comes stock, couple of clamps on the front of the spring. This setup works well enough to yank the left front off the ground on 8 inch tires.
