rear lower control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2001, 05:40 PM
New Member
Post rear lower control arms
I've got a 74 olds cutlass that did'nt come with a rear sway bar but I want to put one on it, the problem is the lower control arms don"t have the bolt holes in them,will i have to buy more control arms or how can I make these work i mean as far as being able to bolt my sway bar in the correct position also does it matter if my control arms are boxed or not?
Old 12-11-2001, 06:05 PM
elcamino72's Avatar
Gearhead
Post
Your should be able to get a sway bar out of the scrap yard for a 73-77 A-body and install it without getting new lower control arms. If I'm correct, the 73-77 A-body rear bars bolt to an insert that goes up into the lower rear control arms. (Similiar to mid 70's B-bodys) The instert is bolted in, it's just a matter of drilling holes. I believe this is how they are done.
Old 12-14-2001, 04:52 PM
New Member
Post
hey thanks for the imfo.
Old 12-15-2001, 09:01 AM
elcamino72's Avatar
Gearhead
Post
Glad to help. Good Luck
