Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Main Seal
Thread: Rear Main Seal
Old 12-06-2003, 06:34 PM
drlindz's Avatar
drlindz drlindz is offline
There is no need to remove the engine.
Remove the transmission and then the flywheel/flexplate.The seal is a one piece.You can punch a small hole into each side of the seal and then thread small screws into the holes.This will give something to pry on to ease the removal.A large seal installer is recommended, but it can be done without it if you are CAREFUL.
This would be a good time to replace the front seal in the transmission.
