Rear main seal-leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 09:46 AM
Rear main seal-leak
I recently had my rear main seal fixed, the guy who did it is a chevy guy, my car is a mopar..but he said the seal went right in, no problem. It wasnt leaking real bad but i decided to fix it. NOW...the car still leaks oil from the bottom of the shroud(the shroud in front of my trans pan) but ONLY when the car is hot ...then it eventually stops. Its not alot of oil leaking. Im fustrated with it..spent alot of cash and it still leaks, dont know if i should have him tear it back apart or not, or should i just let it go...its got a brand new seal! What do u guys think?
Old 05-25-2006, 10:00 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Is it engine oil or tranny fluid?
Old 05-25-2006, 10:58 AM
rear main leak
OIL....again.
Old 05-25-2006, 11:36 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You may need to install an over sized seal to stop the leaking if the crank is worn.
Question on SBC with 1 piece rear main seal Houman SS '70 Engine 6 05-02-2005 11:18 PM
454 Rear Main Seal y5e06 Engine 4 08-18-2004 03:44 PM
2 piece rear main seal Brian Morency Engine 6 07-07-2004 11:54 AM
Rear Main Seal Silentlion_69 Engine 5 12-06-2003 06:34 PM
rear main seal in 350 bstm23 Engine 4 12-02-2003 12:57 PM
