rear main seal orientation - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 03:08 PM
can anyone clarify........lip on rear main seal is supposed to go toward bearing (front of engine) but which lip...the small lip or the big lip?
See photo............is this backwards?
Old 01-26-2013, 03:50 PM
That is wrong/backwards.
Old 01-26-2013, 04:00 PM
yes, it is backwards..........got it flipped around thank you.
techinspector1's Avatar
Wiki Edits: 326
The dead giveaway is the two grooves worn into the crank from the previous seal.
Old 01-26-2013, 06:29 PM
rear main seal
when installing rear main seal stager the parting line of the seal and parting line of main cap and block
Old 01-26-2013, 07:35 PM
Richiehd's Avatar
JS-70
And a TINY dab of rtv where block meets cap
Old 01-26-2013, 08:09 PM
Thank you..........gotta watch the little things right..........
having fun with the oil control rings now.......Doh!
Found a youtube vid that makes it look really easy....
79 3.3 rear main seal etc rp23g7 Engine 1 06-18-2010 07:28 PM
SBC 400 Rear main Vs Rear Oil Pan Seal afsog Engine 12 02-12-2010 05:56 PM
front seal/ rear main seal...help mrobby440 Engine 2 05-11-2006 06:31 PM
Rear main seal Dave Byrd Engine 3 05-01-2006 07:44 PM
Rear Main Seal Silentlion_69 Engine 5 12-06-2003 07:34 PM
