rear motor mudd bogger switch from front - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 07:14 AM
1978 Chevy 1/2 ton 4x4
big block 454
tires 40"x17.5"x15"
How can I Make the turn around
body and bed
or motor
Old 09-12-2006, 04:45 PM
Last journal entry: frame build
[QUOTE=tony echeman] rear motor mudd bogger switch from front
big block 454
tires 40"x17.5"x15"
body and bed
Do a 110 in reverse
or motor
Get a crew cab frame , use the 2dr body and move the engine to the bed. It will look awful strange with the wheels behind the bed. Or, you cold extend the box to keep the wheels in the well but thats going to look strange to. Without the extra frame length, it won't fit unless you use a transaxle or a in-out box.
Old 09-15-2006, 09:54 AM
my plan is to use a reverse turn cam & reverse turn starter
switch font axle with back axle. steering might be a problem
Old 09-15-2006, 07:31 PM
you have a lot more to consider than just engine rotation.Transmission and diff will be running on the backside. Automatics will not work backwards.. What you are proposing is not impossible, but not really feasible.
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
tilt front end -reverse polarity electric switch??? ActionPaintball Body - Exterior 6 11-14-2004 11:31 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
Old olds rear ends Front loader roys63 Transmission - Rearend 1 02-12-2002 12:10 AM
