rear noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2012, 06:51 PM
rear noise
i have a 84 monte carlo ss and a weird noise is coming fromm the rear it is a whine noise when the car is rolling but when i hit the gas it goes away i checked the axle bearings what else could it be
Old 04-30-2012, 07:10 PM
sideshowbh's Avatar
Drain the diff. oil and see if there is meatl shavings in it. It sounds like a ring gear going south or a pinion gear. It could be the input shaft bearing going out. The reason the noise goes away under acceleration is that the gears are riding at the correct angle. Under coasting conditions (with a bad bearing) the angle changes and the gears make noise.
Old 04-30-2012, 07:42 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on the ring gear and such.
Cole
Rubbing noise rear kleen56 Suspension - Brakes - Steering 3 07-09-2010 09:15 PM
s-10 rear noise jschkloven Transmission - Rearend 4 09-18-2007 06:45 AM
Rear end noise need HELP!! mx jim Transmission - Rearend 2 10-17-2005 07:33 PM
65 GMC rear noise mshellw Transmission - Rearend 4 04-17-2004 09:38 AM
Rear End Noise? chevyteen17 Transmission - Rearend 1 04-01-2003 02:43 PM
