rear parking lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2012, 05:38 PM
rear parking lights
Hi,, am installing new wires in the headlight switch, a 73, in my 73gmc truck. The problem is that the rear parking lights stay on. i have pic of the switch. Hope this helps. Thanks frankyjoe
Old 01-17-2012, 07:51 PM
Cape Cod Bob's Avatar
The switch I used had the terminals marked. I would just take the wire off the switch that goes to the rear park light and put it on the same terminal that has the front parking lights on it.
That is. , if the front park lights stay on when the switch is pulled to the headlight position.
Old 01-17-2012, 07:59 PM
Hoptup32's Avatar
I'm not exactly sure what is causing your problem, but the headlight switch requires two power sources, the headlights, dome light, dash lights and front parking lights receive power from terminal 928. The rear parking lights should receive fused battery power from terminal 959, which your diagram is showing handwritten as "Power feed for fuel pump switch"
Old 01-17-2012, 08:07 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
FREE Wiring diagram from Autozone
See Figure 7 for 73-76
Old 02-09-2012, 05:39 PM
bob, the rear parking and rear turn signals stay on with headlite sw off. Thats my prob. i bought a new hdlte sw. and was tested at the auto store. It seems i am getting direct power thru these wires. tested by my trouble lite. There is no key in steering col. ign. Should the hdlte sw control this pwr to these wires?
thanks for any help gmc73
Old 02-09-2012, 07:32 PM
Disconnect the wires going to the rear lights at the switch and check them for a back feed. If they are clean , disconnect them at the taillights and check for grounds.and not grounded the problem is in the switch OR where the wires are connected to the switch. Follow 66gmc diagram or this link I posted. Just keep trouble shooting until located. Wires crossed up, harness misswired at factory, short circuit in harness etc.
http://www.goindesign.com/w4r/EZ2Wire-Manual.pdf
Old 02-10-2012, 06:32 PM
rear lights
bob, the scenerio now is 1 filament litall the timewith batt neg attached. no sw on. ? is the taller filament the turn signal iin the rear tail lights lamp. when trouble lite testing the rear r and l turn signals are lit all the time. at the steering col harness there is constant power thru the l and r turn signals wires. still truble lite testing rear ground wires.
hope this helps gmc73
Old 02-10-2012, 07:19 PM
Not sure which filament is which. The brighter is the brake/turn
The only circuit that should be HOT when the key is off is the brakecircuit and the headlight circuit.
I suggest pulling the turn signal flasher out, the hazard flasher out. These are separate circuits from the running lights. Then see what you got. There is something crossed up and believe me it will be simple. I have overlooked simple things and torn stuff apart only to find it. Then slap myself.
If the lights go out when you do this then look in those circuits for the feed and if it is wrong.
Old 02-11-2012, 04:33 AM
EOD Guy's Avatar
I noticed on your dia that you're useing the org wire from the light switch to pwr the fuel pump. Unhook the fuel pump and see if that solves your problem. You might be getting a back feed from the fuel pump.
Old 02-13-2012, 06:23 PM
rear lights
Hi bob, there is short in the steering col harness the rear turn sig were on all the time. The taller filament is the stop light. Have to replace cancelling cam. thanks for your help. will let you know what happens.
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 06:46 AM
72 Chevelle Parking Lights MI2600 General Rodding Tech 6 10-19-2006 07:49 AM
parking lights to the rear? pro570 Electrical 5 03-29-2005 07:35 PM
parking lights oldsmobilecarowner Electrical 3 11-05-2003 12:14 PM
parking lights lenses bill thomas Electrical 3 06-06-2003 03:20 PM
