rear quarter - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 03:25 PM
rear quarter
I am replacing a rear quarter on my 78 elk. I need to cut the sail panel and would like to know the best way to remove the drip rail? The new panel overlaps at the door. How close to the door do I need to cut to get a proper fit?
Any tricks that would make this go together would be helpful.
Old 11-05-2012, 01:02 AM
on u tube theres a great set of videos called diy autobody with pete, he has a video up thats really close to what your wanting to do. might be a good thing to take a look at . peace
The Following User Says Thank You to inkfreak1976 For This Useful Post:
redsag 78 (11-05-2012)
Old 11-05-2012, 11:01 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If your sail panel is good most bodyshops will cut at the bottom below the drip rail and not go to the factory joint. The door I would cut right at the door and let the new panel overlap into the door jam. You may have to do some work there depening on how everything is build to keep your opening right.
The Following User Says Thank You to swvalcon For This Useful Post:
Old 11-05-2012, 11:15 AM
boatbob2
Panel,,,,
ONLY use the smallest piece of the new panel you can get away with.stay away from the drip rail,that will only open up another can of worms,been there,done that...as stated before,overlap the new panel onto the door edge (where the original was welded) ONLY if you need to...
The Following User Says Thank You to boatbob2 For This Useful Post:
Old 11-05-2012, 04:56 PM
If I cut below the drip rail I have to weld the length of the panel, which is more than spot welds on the top of the panel. Maybe I didn't ask the right question. How do you get the chrome trim off the drip rail?
Old 11-05-2012, 07:47 PM
novafreek6872's Avatar
Nova Guru
I dont know about an elky, but on a Nova you can tap it off from underneath using a piece of a paintstick and a small hammer. Start on one end and just work your way around
The Following User Says Thank You to novafreek6872 For This Useful Post:
redsag 78 (11-06-2012)
Old 11-06-2012, 01:47 AM
You can use a church key on some.
The Following User Says Thank You to Chevymon For This Useful Post:
Old 11-06-2012, 11:48 AM
put up or shut up
the other day I saw the guru of our shop using a tiny slide hammer carefully. It actually came of perfectly to my surprise. It also doesn't hurt to sand off all the primer on the edges of the drip rail before painting it so you don't have too much materials in the way of re-installation.
The Following 2 Users Say Thank You to tech69 For This Useful Post:
novafreek6872 (11-06-2012), redsag 78 (11-06-2012)
Old 11-06-2012, 12:23 PM
That is a HUGE tip Henry! Really, that is a monsterous tip! Keep that film build to a minimum!
Especially with todays high solids products. Film build is crazy on some of these products. If you remember I did a little test a while ago using clear as a primer to fill 80 grit scratches (as I remember they were 80) using a mil gauge to check it, that clear filled exactly the same as our primer!
The Following User Says Thank You to MARTINSR For This Useful Post:
rear quarter window felt TNnova Body - Exterior 4 09-30-2012 08:10 AM
rear quarter rust pontiac racer Body - Exterior 5 10-25-2008 10:17 AM
Rear quarter window removal? GEARHEADWV Body - Exterior 3 12-13-2006 08:35 PM
rear quarter molding 56-210 Body - Exterior 2 11-02-2003 11:15 PM
63 chevy rear quarter panels shesmy63 Body - Exterior 12 09-02-2003 04:04 PM
