Rear quarter window removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2006, 07:21 PM
I am starting body work on my 84 monte carlo ss. I have removed all the glass except for the rear side glasses in the quarters. I havent removed the interior side panels yet, is there clips on the inside or a special way to remove these glass.
thanks
aaron
Old 12-10-2006, 08:58 PM
Remove the interior quarter panel trim and look once you have it removed. Probably held in by nuts. Most cars Ive worked on have been this way. bolted in ( there are studs on back of window glass assembly) and buetyl tape to seal along the window opening pinch weld. I haven't done this particular vehicle, but from what I can tell from ebay pic, it looks that way. Could be urethane adhesived in and need to be cut out like a windshield, but really doubt it, especially being older. Quarter glass i've seen has been bolted in. Never seen one clipped in, unless you are talking about a moulding somewhere. Either way, you want to remove the interior quarter panel.
Old 12-11-2006, 01:36 PM
skeeveman's Avatar
I am the Antirice
That's exactly how it was with my 85 Cutlass I had a few years back. So your's should be just the same.
Old 12-13-2006, 07:35 PM
Thanks guys, as soon as i can get christmas shopping pushed aside i will check it out.
thanks
aaron
Drivers side door hits rear quarter Johnny Bravo Body - Exterior 18 01-17-2005 03:46 AM
stationary malibu wagon rear window 6speedwagon Body - Exterior 7 04-10-2004 11:17 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
53 ford f100 rear window tgregoire Body - Exterior 1 07-16-2002 06:20 PM
40 Ford Tudor rear window regulators Tooch Body - Exterior 1 03-12-2002 10:30 AM
