Rear Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2006, 11:50 PM
BennyDigitale's Avatar
Rear Question
How can a 7.5 posi with 373 gears be "Beefed Up" to hold 550 - 600 HP?
Old 11-22-2006, 07:52 AM
Is this a GM rear end?
Old 11-22-2006, 10:10 AM
Yes this is a GM rear. Coming out of a Monte Carlo SS.
Old 11-22-2006, 11:36 PM
The only way a GM 7.5" rear is going to withstand a typical 600hp engine is to replace everything except the lube with something bigger.
Old 11-23-2006, 06:22 AM
RippinRon's Avatar
I blew my 7.5 in my 86 cutlass with my a 300 (maybe) horse 350. It had 3.42 gears and posi with 255/65/15 rubber. When I took it apart all most of the spider gears were broke. The cure would be a better posi unit but then you would probably break a pinion or axle. Its not worth the money IMHO.
Old 11-23-2006, 10:37 AM
Well, how what would I replace to make it stronger or is there a better unit that will be able to withstand this much power? I'd rather do it once, the right way.
Old 11-23-2006, 10:58 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Google G-Body 9 Inch
Should see results from Moser, Currie, etc.
Old 11-23-2006, 01:23 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
For a primer on stock rear ends and how much power they will support go to this article from Hot Rod magazine:
http://www.hotrod.com/techarticles/axle_rear_end_guide/
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
91 gm 7.625 rear end question???? camaro420 Transmission - Rearend 2 05-01-2006 09:22 PM
67 camaro rear end question shclayto Transmission - Rearend 6 10-11-2005 10:24 PM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 08:38 AM
BOP Rear End question 79 Malibu327 Transmission - Rearend 5 05-01-2004 12:35 AM
12 bolt rear end question Roy_67_SS350 Transmission - Rearend 3 01-04-2004 07:12 AM
