rear seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 11:13 PM
rear seal
how do you tell if an engine is a 1 or 2 piece rear seal?
Old 07-11-2010, 11:32 PM
327NUT's Avatar
Well by the year to start with, then if thats not possible you can crawl underneath and look at the block where the crankshaft exits. If there a round casting bolted there then its a one piece.
Old 07-11-2010, 11:36 PM
im pretty sure its a 1972 350
Old 07-11-2010, 11:56 PM
327NUT's Avatar
Then it's a 2 piece, I think it was '86/'87 that chevy went with the 1 piece.
Old 07-12-2010, 12:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Easy way to tell is if it has a driver side oil dipstick, it's a 2-piece RMS.
Having a passenger side dip doesn't necessarily mean 1-piece RMS, though. Passenger side dipsticks started around '81, one-piece rear main seals began around '86.
79 3.3 rear main seal etc rp23g7 Engine 1 06-18-2010 07:28 PM
SBC 400 Rear main Vs Rear Oil Pan Seal afsog Engine 12 02-12-2010 05:56 PM
SBC Rear Main Seal: Thinking Man Engine 12 03-12-2008 03:45 PM
Corvette 68 Rear End Pinion Seal... Mean@MeanMother Transmission - Rearend 5 06-08-2006 11:07 PM
front seal/ rear main seal...help mrobby440 Engine 2 05-11-2006 06:31 PM
