rear seal leak on sbc 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 05:58 PM
4onthefloor 2's Avatar
1968 chevelle
hi i have a 1974 350 with rear seal leak Ive replaced 2 times and it still leaks i even off set the seal and its still leaking is there a better seal i could use for a stubborn leak like this thanks for the help ps cam plug and oil gally plugs are not leaking and rear seal only leaks when motor is running
Old 02-15-2005, 06:32 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
When you said offset rear seal just what do you mean? you can buy a offset rear seal that moves where the seal runs on the crank. I've used these with good results
Old 02-15-2005, 06:41 PM
302 Z28's Avatar
When he says offset the seal, he is refering to partially rotating the seal halves in the block and main cap. This is so the parting line of the two seal halves are not inline with the main cap/block parting line.
How many miles on this 74?
Have you checked the PCV system?
How much blowby does this engine have?
I have seen engines with excessive rear main bearing clearances that no amount of seal replacemnts could stop a leak on.
Vince
Old 02-15-2005, 07:01 PM
1968 chevelle
motor is fresh only has 6 hours on it. rear main bearing clearances are fine PCV system is working. should i try an offset rear seal or a double lip seal if so could you recommend a part number thanks Rick
Old 02-15-2005, 08:13 PM
Be careful it's easy to install the seal backward.It doesn't go on like it looks it should.......not that this has ever happened to me
Old 02-15-2005, 09:40 PM
Mike_82's Avatar
maybe the oil pan is bent slightly in the seal area?
Old 02-16-2005, 07:23 AM
1968 chevelle
oil pan is new its the seal.should i try an offset rear seal or a double lip seal if so could you recommend a part number has anyone tried either of these seals thanks Rick
Old 02-16-2005, 08:55 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I would just run it for a couple of months, how bad is it leaking? I've seen a few leak and then tighten back up later on after a few hundred miles. Almost like they're "breaking in"
K
Old 02-16-2005, 04:22 PM
1968 chevelle
car is a 4 speed and i dont want to smoke the clutch
Old 03-23-2005, 04:04 PM
1968 chevelle
found the problem guys and feel really stupid, for wasting you guys time just thought I let you know what the problem was rear back corner on driver's side rocker cover was leaking pretty good. After motor runs for 5 mins, oil would run out of lower back corner down around oil filter boss, and drip under centre of car. When I bought the Elderbrock alumium rocker covers I dropped one, and that's the corner where it hit the floor, I've since switched rocker covers from left to right and bought good gaskets, problem solved thanks guys
