Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear shackle help
Old 08-24-2006, 04:40 PM
johnnymopar's Avatar
johnnymopar johnnymopar is offline
Love your nails! You must be a Libra
Rear shackle help
to make a long story short, i had to make new rear rails on my frame. the frame is a '88 dakota frame and i had to make the rear rails lower.
i was using the dakota brackets and shackles but now the frame is made with 2x4 steel and the end of the leaf spring is beside the rail. see here
i don't want to go above the rail with anything because of the trunk floor.
i know on a lot of GM trucks, the shackle bracket is below the shackle. i could do that but i don't have a bracket and with the 2x4 frame, there isn't a lot of material to attach to.
i was thinking of using a 5/8" or 3/4" bolt thru the frame to use as a pivot point for the shackle. i could put a sleeve through the frame and reinforce it to keep it from bending. but where do i get a sleeve with a 3/4" I.D. that i can weld to? i've seen galvanized pipe and black pipe for plumbing but i don't know if you can weld to that.
any ideas appreciated.
"Well done is better than well said." - Benjamin Franklin (1706-1790)
